NEED HELP ASAP
My wife's 2009 Dragon 600 is having some issues. The temp gauge wont read past 48-50 degrees even after ideling for 20 minutes. I have already swapped the thermostate thinking it was stuck as well as the temp sensor and still no luck.
What could be the problem? Both pots are running at perfect temp as well as the tunnel coolers are both hot so coolant is circulating though no problem.
I have hit a brick wall and need some advice on what the problem could be. My dealer has no idea.
Thank you
Thank you
Sounds like it's on Celsius instead of Fahrenheit
50* Celsius = 122 Farenheit, which sounds spot on for operating temp.
as others mentioned prior, you might try changing your gauge from metric back to U.S.
if not, you might check the temp sending unit for accuracy.
  • Like
Reactions: sw
Yup, sounds like it's in Celcius... it should say on the screen *C or *F depending on mode... it will also read Miles or KM on the mileage screen. If you want to switch it over, press and hold the "Mode" button for about 12-15 seconds, that will switch everything from U.S. to Metric and back.
