O
I have a 2012 HCR that has been in summer storage in my back yard shed since April 2015. I have gone out once a month to start it up and let it run for a few minutes to run fuel and sta-bil thru the system. I went out yesterday 10/4/15 to do the same thing but it will not fire up... I checked the kill switch and al the wiring behind the kill switch block on the handlebar and everything is fine. I checked the tether connection and cleaned everything up just in case, and still nothing. I then moved to the plugs, I removed all 4 spark plugs and gave the sled 20 pulls to make sure it wasn't loaded up and put 4 brand new spark plugs back in, I checked the plugs for spark on the head bolt and I have blue spark all the way around. Lastly put a little bit of fuel down the cylinder and it would fire right up first pull and run for 3-5 seconds until it used up the fuel and then it would die again. I did this 4 times hoping it just needed a few tries to get everything flowing again but no such luck. Everything sounds like a fuel supply issue but everytime I check a plug they are wet with fuel/oil?? Maybe it is getting SOME fuel in but not enough to fire?? What else can I check? I started pricing fuel pumps but I want to try and avoid spending 400$ on a new pump if I'm not sure that's exactly what the problem is.
Thank you in advance for your help!
