ok heres the deal... ive got a light bog or sputter when i am just on flat ground playing around, and this is about 90% of the time. and when i climb it just loses power and have to turn and go back down, i make it down and go right back up and it shoots up the hill effortlessly
then the same day when this problem came up it would only rev up to 6500 rpm , i had a broken lower exhaust valve so i replaced it thinking i fixed the problem, but i still encounter this stuck at 6500 every once in a while. before all of this i had a big back fire while starting it, that is when these probs began.
things i checked...that are all fine.
exhaust valves
heads
pistons&rings
plugs
reeds
boots
vacuum hoses
so i am lost. please anybody, got any suggestions.
help a fellow snowester out!
exhaust valves
heads
pistons&rings
plugs
reeds
boots
vacuum hoses
