Just redid my sled. New long block,ecu,stator,reeds,and knock sensor as per dealer. Have reset the TPS and still not running properly. It starts on third pull idles around 1800 rpms for like a min then cuts down to 900-1050 on its own and wont idle any faster. When I tried to run it around the yard with your thumb in one spot it just keeps acting crazy (rpms going up and down but not moving thumb). Resistance tested TPS sensor and harness and all came up fine.Also resistance tested injectors and they are also fine so definitely stumped and dont know where to go from here. An help from u guys would be appreciated.It is also flashing the code 10 for cps sensor but told by dealer that code is redundent so dont worry. But with new stator and everthing testing fine for resistance still no go.
