Need extended brake line 07 Apex??
I need a brake line that is in the 46-48 inch range for my 07 Apex mountain.
Anyone know who has them??
I bought a Fly one but obviously its for a short track! It's shorter than the stocker!!
I have a rolled case so the stocker is already tight. Now I'm raising my bars 3 inches. Stock brake line is around 42 inches and I wouldn't mind a bit more slack than I have now. Hence the 46-48 inch line.
Sap
"Stick with 2" riser and everything fits nice."
I have a rolled case.....which takes out all of the existing slack from the stock line. Hence the reason for a longer cable.
Trust me if I could get by with out a longer one I wouldn't have posted this! Thanks for the wonderful insight!!
I am sure that throttle cable will work wonderful on my brake caliper!!;) LOL
I have found a few options but none of them are vinyl coated. I would prefer to have one that is vinyl coated.
Russel sells them but I called and they are not vinyl coated to help with abrasion
couple of options you might want to try
look through summit racing (or similar) and see if you can piece together a couple sections to get the correct ends that are needed.
go to a shop that builds custom hydraulic hoses and see what they can do for you, they might have the correct dies to do the work.
I have no idea where a place like that would be, but I do know of one in Illinois. :rolleyes:
I assume the line is banjo on both ends?
I found a place in Kent (Thanks Ultralord!) that will make it exactly how I want while I wait!! $50 bucks. I am taking the stocker down and they will match up the ends and put banjo fittings on with no other joints. They have stainless braided line that has a smoked color vinyl over the top with an OD of 5/16.
Thanks for all the replies!!:beer;
