need code help!!!
haven't work on this sled in awhile and can't remember codes.(my old sled) put a new monster riser and bars for the kids sled and had to change oil and throttle lines, and brake line. (had to open coolant to get to brake)temp light flashes four times then a pause, then repeats. i dont have a rear cooler so bleeding the system for coolant involes turning it on its side clutch down and repeat a few times. tried it and didnt help. is this a coolant issue or a diffrent problem. maybe wiring hand and thumb warmers, kill switch? was perfect before i started. sled is a 01 srx long track THANKS EVERYONE:D:beer;:beer;:D
anyone?? know 5 blinks is a servo motor for power valves, but four??
think it coolant or wiring any help???? getting drunk to fast and loosing my patience, started to throw tools aready:mad::beer;:beer;:beer;:beer;:beer;:beer;:beer;
it has 4 quick blinks thanks ill look at wiring and keep tring to bleed it:mad::beer;
wiring looks fine and tried to bleed it again even ran it for 5 min for the stat to open and still nothing. going to run it till it blows fug it
engine overheat is a continuous flash. my long track srx does this in wet/heavy snow or hard pack trail as to the heat exchanger placement on the aftermarket tunnel. the temp sensors are set low enough from the factory that i dont think they are "overheating", kinda a safety feature. if you get into the fluff or take a break and pack the running boards with snow, it will go away. as long as your coolant is flowing, assuming you checked that, ride it!
it flashes 4 times then pause then 4 more. webmaster from ty said it could be improper voltage, maybe a bad switch or something got unplugged. anyone ever seen this problem i thought constant was overheating never stopped flashing too, 5 flash was servomotor, and all others had the long flash then the quick ones. sitting in the garage and havent hit with snow since the problem but leaving with the son for 5 day trip and trying to avoid a rental and a belt for mine from towing it back. leaving thurs. night. thanks so far for the suggestions
:D:beer;:beer;:D
muskoka
thanks for the try but it doesn't match any of thoses. ive seen them and even have the book on them(service manuals) but it has the same speed four flashes, then a pause, none of those match, think it electrical
:beer;:beer;:beer;
