need clutch info fo 2005 summit 1000
I run a Team on my 1000. You need to get rid of those stock arms in your primary and go with Dalton 60 gram arms, and about 16grams worth of pin weight and the stocker 230-380 spring. Your team will be great with a 44-38F, and a Team 160-260 spring. Start with those and you will be set for high elevation. If you do happen to keep those stock 80 gram arms at high elevation you will find out quickly that the stock setup doesnt like to pull RPMs and your RPM will jump down to 6000 alot and not recover ever. Do yourself a favor and get the 60 gram arms. And a Thermostat is a must for this beast.
