Need a little help with Kmod
onepicknick
I bought the Kmod Conversion and I don't understand one thing 10.Install rear idler wheels from original rear arm on upper cross shaft, center shaft and put blue Loctite on set screw.
11.Hold up template to the inside of the rear drop bracket with small hole to the rear, it will fit flush, align so it matches the outside of the drop bracket and mark through the small hole with marker. Center punch and drill a pilot hole using a 3/16th or smaller bit, then drill the pilot hole to 3/8’’; this is the new mounting hole for the rear arm in the drop bracket. The rear arm must be mounted here for correct geometry and operation.
So let me see if I get this straight Take off the Idler wheels and put them on the new Shaft then drill the new holes in the drop down bracket in which I should bolt on in the old location with the shaft to get proper hole location for the new hole with the provided templet. Now the wheels will be higher because of the new location?
Wish he would of provided some pictures does anybody have some pictures
