I have a set off 40-116 SLP MTX™ Clutch Weight, 4 Weight Clutch, 68 gram with all of rivets except the ones used in the weight themselves.MTX™ weights allow you to run 4 grams heavier per weight than you would normally run with OEM weights. MTX™ weights are adjustable by adding weight via rivets (up to 6 grams per weight) to achieve desired peak rpm. New they are $65 for 2 and you need two sets=$130 for a full set. $80 To your door them me know. http://www.slp.cc/catalog.cfm?pageID=detail&view=description&catalogID=2&catID=5&productID=276
