I had the same thing with my 2000, 1500. 5.3
It would crank but never catch or turn over; I could not hear the pump run when I first turned the key on. (I hit the tank with a trailer hitch alos) The gear indicator on the dash did not show what gear I was in the lights were all on. And I could not shift my transfer case into neutral (Holding the 4Hi and the 4Lo buttons for the 4whell drive)
Checked the fuse had the relay checked and I had put a new fuel filter on.
So I changed the fuel pump last night. Works like a champ now it seams like I have more power now also don’t know if that’s true, unless with the pump going bad it was not putting out the pressure it should?
Gear selector works right now but the ABS light on the dash was on I drove around the block and it went out,My guess is because of the towing. (Gas gage works now also)
Good luck!!
Well I checked the battery and fuses and all is well there so its on to te next thing. I'll keep everyone posted.
Has there been any resolution to this problem? I am still curious.
Anvil
