My take on end of season things to do, I think one should take a trip around the sled and look, then grease where necessary as I have found some water in most bearings at the end of the season and if they are greased, the moisture is pushed out and fresh grease, so no rusting inside the bearings over the summer, used to take tension off the track, but I have taken to just starting the machines up once a month and running track,clutching up to speed once or twice while temperature to 125 or so and shut down and walk away for another month or until SNOW COMES. I also put the recommended amount of Sea-Foam in the gas on the last ride and then jest leave the tank 1/2 or wherever and fuel next season with new non-eth fuel "Think Snow"
gtwitch in wyoming
gtwitch in wyoming
