My stock nytro XTX weight.
I put my nytro XTX on the scale at home (it not certifided but close enough) and it tipped the scales at 568lbs. This is in stock form, the way it came from the dealer with just enough fuel to load it on the trailer.
lets say 565 (3 lbs [1/2 gal] of fuel???) to round it off.
add 7.3 gal (47.45 lbs [6.5lbs / gal]) to fill the tank full.
612.45 lb wet, stock (with 7.3 gal of fuel, prob can't get quite that in there by what I've read, but we'll go by the book).
weigh it the same after you install the Impulse kit...curious to see the difference.
or, weight them both fully wet...and calculate for an additional 2.7 gallons (17.55 lbs) on top of the stock wet weight. then wet weights are equal according to fuel..
should be intersting..i've wanted to see what the kit weighs alone for my own calculations.
