The first step is admitting you have a problem
Hi my name is Matt, and I too am addicted to boost. Sure it's only 6-7 psi for now, but I'm afraid in the future I will be needing 12 psi to fulfill my urges and desires!
Throttle response is a lot better without the leaded fuel![]()
Somethings not right.......You shouldn't notice a difference at all. Unless the added pressure is heating up the intake charge temp and lowering the boost lowers the intake temp. I have run mine on both and the fuel makes no difference. Higher charge temp also make the motor richer...maybe the motor being rich caused it to be lazy..not the fuel.
IDK, it just seems a lot crisper to me running 91 pump gas than straight 100 LL on the bottom end,.
I heard there was gathering of you addicts last Sunday, with the king-pin himself on site handing out PSI like it was candy.
