After Christmas I dropped off my 12 Pro 163 with 2,286 miles at A2D Sledworks in Anchorage for a top end and an LR upgrade.
I got the following:
-PAR crank & rods
-PAR 12.5:1 head
-SPI double ring pistons
-New primary spring (I had it clutched last year)
-Clutch weights adjusted
-The usual gaskets and fittings that come with a rebuild
Chad called me today to say it's ready minus some steering post bushings.
I babied this sled since owning it (Dec 16th 2012) and was curious to know how the inside looked--Good news and bad news.
Good news:
A compliment that the sled was obviously well cared for. I did have some very minor piston scuffing--much less than expected for a motor north of 2,000 miles. The rings were pretty well flaked but that was expected. SO, turning up the oiler and religiously warming it up works.
Bad news:
The brass gear on the crank that engages the gear that drives the oil pump was badly worn (I forgot what it's called). I was, in Chad's professional opinion 500 miles (give or take) from catastrophic failure. Progressive wear of that brass gear translates into faulty oil delivery and eventually it would stop oiling the motor enough. Or brass shards could foul one of the other bearings. Either way, bad JuJu.
Otherwise the crank was in good shape.
I'm curious to know why Polaris would use a brass gear in a high rpm application? Especially since the gear it engages to drive the oil pump is steel.
Next step--break-in. And I've got a hundred miles of untracked river powder tucked away for just such an occasion!
-PAR crank & rods
-PAR 12.5:1 head
Good news:
Bad news:
