My brand new axys is leaking some fuel
glowa
Its not much, more like sweating around the red/blue fuel line connectors by the coolant reservoir, but the surrounding area is also splashed with fuel a little bit. Do anyone else have this problem? My buddy with the same sled have exactly the same problem. I did try to disconnect these connectors and put them back in but it did not solve the problem...
I'm pretty sure mine was doing what you described for a little while, then it stopped and hasn't done it since. Not sure what changed things?
Mine ended up losing the connection on the return line. Dumped a tank of fuel into the belly pan lol. Just reset the fittings, and new snap ties to hold them in place was the fix. Been good since.
I have seen some of the clips on the fuel line outlet or fuel rail inlet that are damaged and not "clicking" in correctly and they leak. They will replace them under warranty.
If you are leaking fuel GET IT FIXED. You don't want to have a fire.
Are you sure it is fuel leaking? We noticed what looked like fuel leaking from the fuel line connectors on my brothers last weekend; splashed all over the place. However, it didn't smell like fuel or antifreeze. Stopped into local dealer and he noticed it was oil from the pull rope. When you pull the rope it squeegee's oil out of the rope around the plastic collar (where the rope handle rests). Look there and just under it and you might find your answer.
^^^thats exactly what I found too. The plastic behind the fuel lines looked wet all the time so I thought it was from the fuel lines,nope didn't smell like fuel and it wasn't anti-freeze.
Yep.
Oiled rope.
