My Axys P85 clutch is down, Can I use my 2013 PRO primary, secondary, and 1115 belt?
D
dude
My 2016 Axys primary clutch is down... Question, can I use my 2013 PRO primary, secondary, and 1115 belt for a short time until I get my 2016 primary replaced? I'm hearing the main difference with the 2016 Axys primary is only the sheave angles. If this is the case I should be able to use my 2013 PRO primary and secondary with the 1115 belt. I know the Axys uses a different crank but is the taper the same and therefore good to go with the 2013 P85 clutch?
Yes.
Lot of clutch replacement threads eh.
I do believe Poo has found the rpm limit of the P85.
