No intercooler, seeing charge temps at 50-60celsius.
The bogging problem i had is gone, im 90% sure it was because of the timing key.
Im running Rktek head that has 10.2 in compression vs. stock that has around 12.9 I think. And im running Rktek/Wössner pistons that are much lighter than stock, and has a better fit.
After rebuilding the motor, adding the head and pistons, and removing the timing key, the response is actually better that with the timing key and stock head. Not by much but enough to notice.
Response vs. stock isnt really comparable, stock is way faster and more crisp than my setup. I blame alot of that on the clutching, im running 42/48 helix, but will change that to a straight 48.
Power from stock to turboed isnt worth talking about, im riding with a stock assault same year, and other pro rmk's. Its actually booring riding them after riding mine.
So tip of the day, remove the timing key. Yes you can run higher boost on bad fuel, but its worth turning down the boost and removing it, or just buying a turbo head instead.
