While I was out riding this weekend my sled would pulse in and out of power while I was WOT. Didnt matter if I was on the trail or in deep powder climbing a hill. It would go up past 8000 rpms and then surge down to around 6800 and back up. I checked the plugs and belt-everything looked good there. It would run great all through mid range, just not when I punched it. After a couple of hours the check engine light started flashing 5 times.
Called it a day and drove home. Checked the code and found that it was my exhaust temp sensor. Left it on the back of my truck for the night.
Next morning I got up and looked under the hood and the sensor had rattled out and was laying below my pipe. Threaded it back in. Started on the 3rd pull (It had dropped to probably -10 over the night) Let it warm up-pushed the reverse button-backed it off of the truck-pushed the reverse button again....dead....will not start....
Ive about pulled my arm off trying to start this thing!! Ive swapped plugs multiple times. Pulled it to clear fuel between plug swaps. Pulled it into the garage and let it sit over night. Gave it fresh plugs and still nothing...Yes my key is on and the kill switch is pulled. The plugs are wet when I pull them so Im getting fuel. Ive got spark on both plugs. Im at a complete loss, please help
