Multiple CODES: 2015 Pro Rmk
Iowa__Freeriders
Have a friend with a snowchecked 2015 pro 800 155" all stock, 150 miles. has been randomly die and completely shut off. didn't happen a lot just intermittently. throwing codes:
P1336
DET
P1337 (X3)
P1447
P1552
P1279
Wondering if we can get any help or answers?? we are planning on going west January 7th.
any help would be awesome!!!
Call the dealership. They have 3 years of warranty on the 2015 SnowChecks.
it is/was at the dealership this week, they didn't figure out much and unfortunately they are closed today until Monday and there head mechanic is on vacation. (head as in only sled tech)
so im just trying to get some ideas to bring to the table come Monday so we can solve this!
In Sioux Falls?
They should be able to tell you the codes? I would call around.
P1336
DET
P1337 (X3)
P1447
P1552
P1279
P1336- knock level MAG- maximum set correction limit reached
P1337- knock level PTO -maximum set correction limit reached
Can't find your other codes...
Murph
wow not looking good, thanks that's what im looking for he's a town away so ill make sure he checks the manual! any idea what would cause such an issue???
P1552 Throttle is stuck.
That was from a 2012 service manual and the only other one I could find.
Found that the Pxxxx codes are the obd2 version used on digi wrench so he wont find the right codes in the manual, different codes when you check yourself on the cluster!
Codes P1336 and P1337 would mean to much engine knock for the ECU to compensate by retarding the ignition (?) and as far as detonation/knock goes bad fuel or fuel starvation are probable causes.
And knocking is very very bad....:face-icon-small-sho
I would start out by:
draining fuel tank
Checking fuel filter
Fuel pump flow rate
Check make sure fuel pump wires aren't shorted by overstructure/ behind ECU
Still a problem:
Check ignition
Stator
Wire harness/ wire connections
