Mtntk blowhole/venting axys?
Just picked up an axys 16 rmk 155. Had a mtntk blowhole on my pro and it worked awesome just wondering if anyone has run one on an axys. Or should I just get some WRP vents for $99 and safe myself some money. Or should I even bother at all. Thanks again guys!
highly recommend the blow hole. I ran one on my 16 and put one on my 17. If you havent looked into it yet, they vent out the side panel on the axys.
Check ebay if you want some better pricing. mntk sells them on there under a different user name at a reduced price. Eric
If you are wanting to add venting, the blow hole is the best system out there - in my opinion.
Awesome thank you, the system I had on my pro had a vent on the quick drive side but the axys one doesn't? Should a guy add a few vents over there or not worry about it?
They do offer a vent for the Quick Drive side that matches the vent you install on the clutch side. Personally I dont run that vent. I want the fan to pull outside air from the stock hood vents and NOT try and pull air from the hot exhaust side. Eric
How did the blow hole do after a season?
What if any additional venting did people do?
exactly what search keywords are you using? every time i search for "blow hole" i get a bunch of blow up dolls and gimp masks.:face-icon-small-sho
mtntk blow hole
I just looked and there currently isnt any axys kits on there. They may have stopped selling them on there. this post was started a year ago.
I've got a 2011 assault out in the shop with the blow hole installed, it's amazing just how much air that thing blows out the vent at idle and it probably increases as rpm increase. I will buy one for my 12 pro for sure.
I personally did like the Blow hole on the RMK Pro MUCH better than the Axys-
On the Axys, it has a 90* bend to come out the side panel instead of the LONG
straight vacuum draw tube that would funnel more air on the 12-15's Pro RMK
It's much nicer on the knee for sure on the Axys- but every bend, reduces air flow significantly.
I pulled mine -and not reallyany clutch heat difference... must be the spot on TRS clutching that works so well..IMHO!!
Heard an interesting theory... how can a blow hole work well without an intake and sealed clutch compartment? Wouldnt you just be sucking hot air from the pipe and motor across the clutches?
Maybe so but for any warm air that comes out cool air is coming in, most people that have the blow holes seem to like them. To each their own I guess.
