Whistler Hawk,
The guy at justgastanks.com told me outside diameter was 4.25" and that the holes were drilled on a 4.00" diameter. I totally beleive the 4.25 but I dont beleive the 4.00" Diameter Bolt Circle, he must have measured it wrong for sure. If you look at the back-up ring and gasket that you have to buy with the cap to have the hole sealed : (
http://www.justgastanks.com/store/index.php?main_page=product_info&cPath=68_80&products_id=897 ). If the Outside diameter of that is 4.25 I think there's something like 3.25". I was sure enough so I ordered one last week, should get it this week. Will keep you aware when I'll get it.
Top filler will definetely be the best area to retrofit that, I agree and we have enough room to drill a 3" hole no problem and drill a 4.25"-4.5" hole in our plastic.
Relocating the fuel line fitting to the top and add a shut off valve doesn't seem like a bad idea at all J&L.
As for the pick-ups, I would like you to go and have a look at how A-C arrange theirs, sorry I couldn't copy the exact page so you will have to do a bit of work here :
http://arcticcat.arinet.com/Empartw...b&LoginID=cotest&loginpwd=cotest&partner=ARCC
Once you're there, type "Crossfire" then choose any model there, then click and click on the "FUEL PUMP ASSEMBLY" drawing.
Seems like one of the 3 pick-up has 2 connections; one to another pick-up and another one to the fuel pump, I don't know if we should go ahead with something like that, if there's a reason for that OR just go with what you propose, split the hose with a "Y" that connects to 2 pick-ups.
Tank foam : you stuff it. One question I have is I am kind of wondered on the fact that this foam may retain some fuel though... If, for example, there's always 1 liter being trapped into this foam, it wouldn't be awesome. I'll get more info on that as well.
