MTN Addiction fuel can
C
cjfox
So can you run one on a 13? new to polaris and was told you couldnt could someone please tell me if the tunnels are the same as 12's with the channel system( how the seat bolts down), also has anyone ran a skidoo fuel can on a pro? thanks
Whatever you put on the tunnel make sure it's under 15lbs, If you carry more weight look into tunnel reinforcements. They're a known weak link.
whatever was run on the 2012 should fit on the '13's tunnel
I have one sitting in my shop for my 13. Test fit is fine. Mountain addiction is a great company an has great products. I have always been super happy with thier track rack system. The mounting on the Polaris is so simple too. I'll post a pic once I get it installed.
MA
Mountain Addiction is a fantastic company to deal with, recommend just giving them a call. I've used them on all previous sleds. I will be installing one on my 13' Pro as well, clean fit.
CJ,
I have two sets of MA rails on my '13 that came off of my '11 so no worries.
To my knowledge, the only change on top of the tunnel assembly is the new seat support only utilizes one bolt per side where the prior sleds had two. Also there is an additional 4" of tunnel length due to the shorter seat reach.
Cudo's to MA for being a great company, both products and customer service, they are second to none.
Bag
Where are all you guy buying youre mtn addiction track racks and jugs from? is one website cheaper than another or they all about the same?
Just picke-up the lowprofile bag kit and combo pack for a 2013 163 PRO at the Washington Sno Show. ~15% off.
