E
endeavorslc
New member
The High Performance MPI Nytro Exhaust System saves weight but increases dB levels. The new exhaust system weighs just 4.75 pounds, with the OEM system weighing over 17 pounds. It was designed for use on Stock and Supercharged units. As this system has significantly less backpressure than the OEM system, Turbo should consult their kit manufacturers, as the increased flow and reduced backpressure will likely be detrimental to a turbo's performance. The system is made of 100% stainless steel and exits through the stock cowling behind the seat. The unit includes a billet aluminum tip.
$200
$200
