Moutain Max Mod. !
B
bigsno
New member
I have for sale a 2000 Mountain Max Mod (I switch the blue plastic out for the black). The chassis has 5,858 miles on it. 500 miles ago the engine was completely freshened for preventative maintenance. It got a new crankshaft, pistons, rings, and gaskets. 300 miles ago, I replaced all of the drive-bearings and seals in the chain case and in the skid. The sled is jetted and clutch for 8,000-10,000 ft. If you want to see more pictures send me your email and I can send some more. It is located in Stuart, Nebraska. My phone number is 402-340-0505. $3200 OBO
Modifications:
-Mad Max Performance cylinder porting
-Ekholm tunnel
-Dropped and rolled chaincase
-Hauck ceramic coated triple pipes ( The silencers are modified coming out of the side to eliminate powder bog in deep snow)
-Lightning Pro roller secondary
-Boss special edition flat top High rise seat
-Works Shocks all the way around
-PLP lightweight trailing arms
-35mm carbs
-Lightweight radius rods
-Nytro Mountain Skis
-Remote air screws
-Holtz Ice scratchers
-Power Madd handguards
-Rox riser plus 4" riser total of 6" of rise on the handle bars
-RSI extended throttle and oil cable
-Gravity Works steel branded brake line
-Extended wiring
-MPI transfer enhancement kit
-151X15X2 Camoplast Challeger fully clipped track
-9T Wahl brother extrovert drivers
-19/40 gearing
-Airbox modified
-Steering colum stiffener
-Custom gas rack
-Boost bottle
-GYT skid plate
-4 SLP Flow rite intakes in the dash
I am sure I am forgetting some other stuff.
I also have some extra stuff that I would let go with the sled for some extra $$.
-Avenger III race pak
-P85 clutch
-Ohlin remote resevior shocks for up front and KYBs for the rear.
