Mounting a 99 600BB in a 99 440 edge advice.
Can somone steer me in the right direction for motor mount straps, What model do I need them from, I think 01 600 edge classic will work but is there anything else?? I am building this for a back up water-x sled.. I race on a skidoo but I got this edge free and the 99 600 I had so any help would be great.. And also I need to know if edge pipes will work with the BB 600 cause I need twins.. Thanks in advance..
Hmmm... you are going to want to use the 99 Edge straps. I believe the bolt pattern should be the same. But regardless, drilling for the motor is easier than trying to adapt something to chassis.
Pipes... you will want 600 BB pipes. The small block ones are different. I don't know anyone that made twins for the 600 BB, but if you can find them you'll just have to fit them to the chassis.
I'm assuming you'll run carb filters instead of an airbox? If not, and you want to run the airbox, you'll have to switch the carb adapters to get the spacing right.
sled_guy
Man we had 600 bb polaris's running around here with slp twin's? Are you sure no one made them?
