Mountain tech 5ft cooler
ullose272
3,372
965
boise idaho
Id get the cr racing cooler, tbh, my 5ft cooler isnt working real well now with the 3" track
Sent from my SM-G973U using Tapatalk
summ8rmk
Most handsome
12,369
6,043
yakima, wa.
This?
I agree the rear cooler is better but u have to cut ur cooler open and weld this in. Mtn tek is drilling holes and bolting in.
Sent it
Sheetmetalfab
7,998
6,775
The Promised Land……..
Myself and my brother ride side by side.
Both tunnels cut 7-8”
Both silber turbo 800’s
His is mtntk 5’ cooler only. 162. X3 track
Mine is welded stock tunnel. 162 3” PC track (Haven’t installed my mtntk)
They run very similar temps. (His slightly higher)
I think track is a lot of the equation.......
The ONLY reason I want to do the mtntk is eliminating the ice buildup on the running boards.
ullose272
3,372
965
boise idaho
I still have ice buld up, tho probably not as bad
ullose272
3,372
965
boise idaho
Do you use a tunnel pack?
Matthew runge
Goldy
88
35
18
40
Minnesota
Yeah I am not sure what to do at this point getting a lot of mixed reviews on everything. I would like 8in of tunnel cut off but from what I understand there is pretty much no great way besides cutting and welding the factory cooler and then adding the 5 ft cooler and that just ends up adding a bunch a lbs. but maybe losing some on snow and ice pack. But is the only way to keep cool on train and spring riding. And not to mention I am not a big fan of spending 800 bucks between the 2 coolers. One being the cut and weld job costing about 500. I do not know what to do. But hopefully polaris can pull there heads out of the sand and stop build sleds that the tunnel is so long a guy could have a dance party on the ****er. And maybe all a little cooling and help to not carry so much snow & ice.
HECKS
424
250
Sylvan Lake, AB
^^ If you cut and weld, you do not need to add additional cooler. Scratchers and removable flap (if needed)
Matthew runge
Goldy
88
35
18
40
Minnesota
I am not sure. My stock sled will set the temp light off at this times when the snow is ****ty and I want to put my snow flap back on. It sux for anyone to ride behind me
