Mountain Cat & 1M Question
I was wondering if anyone has moved this bolt to another slot.
I think it makes it ride less on the skis but not sure.
Surely somebody has done it. I rode one with this done and you can ride wheelies like crazy. I just want to know the advanges and disadvangeds. This bolt is right below the gas tank close to the foot holes.
I moved it from the top hole to the lower rear to set my suspension back to clear my extros and to fit a 156" track on my 151 rails. I did the whole skid though, I think there are holes in the rails where you can move just that front suspension arm. But then your limiter strap is going to be too loose. I would say try it, see what happends. If it doesn't fit or it rides rough put it back the way it was...
If you look on the inside of the tunnel there is actully about 6 different holes, they just arnt drilled yet. You can move your skid around all you want to get the desired ride out of the sled.
