Mounting was easy. Remove your rear drop brackets completely, you don't use them any more (drop weight there). The front mounts in the stock holes and there rear mounts 13 1/2" from the front holes. They send you a reinforcement plate that rivets to the inside of the tunnel that spans the 13 1/2". Remove the stock skid, remove the rear drop brackets, mount the reinforcement plate, bolt the front in, let the air out of the rear shocks, mount the rear in and then fill up the shocks again. Took about 2 -3 hours to install. If you want a step by step video direction of it, Jlowe from Team Summit, did a extra in his last video for the guys at Mtn Addiction.
