yes you can put it in, no it doesnt bolt right up, its quite a PITA actually.
did it with a 06 chassis and put a 1000 motor in with a turbo... used the cat brackets, pto and mag side bulkhead mounts, need to use the m1000 steering post to clear the spark plugs, EVERYTHING needs rewired. honestly if i had to do it all over again i wouldnt. sell the sled and start with a used m1000.
with that said, D&D makes a kit for like $550 bucks that supposibly makes this a drop in setup, gives ya everything you need. i didnt look into it that extensively at the time because i figured i could do it for way less... pretty sure i was wrong on that one.
hope that helps
