Took the sled out for the first time last week. Ran great, towards the end of the day started to get a little noise from the motor. Same noise I got from my old sled when the PTO side cylinder went bad. The noise sems to be the rod rattling on the crank when there is too much slop in the cylinder / piston. On my old sled after I did the top end the noise stopped.
I tore down the top end on the new sled and the cylinders look great and the pistons look pretty good (no major scoring, cracking or missing pieces).There was however, too much play in the rings, making the pistons loose in the bore.
All this to say, I was wondering how much play should there be in the rod bearings? Don't know if I should just do the top end or if I need to do he bottom also.
2002 800RMK Vertical Edge 156
