M
mike_s
Hy guys, ive got a stumper here. A '96 (ish) ultra, 850 mod with alot of extras. Its developed an interesting habit of dying at full throttle. Just like you hit the kill switch. No burbling, misfireing, backfireing or anything like that, it appears as though the ignition cuts off entirely. But heres the kicker: after the engine winds down, at about 700 RPM, the engine catches again and sits there idling as if nothing has happened. Its 100% consistent on catching and idling after this occures, but the length of time at WOT before witch it happens seems to be random, sometimes i can go an eighth mile, sometimes 5 feet. Only does it at WOT, never anything under that. The vent lines in the fuel tank are fine, not plugged, fuel pump is fine no leaking diaphragms, fuel filter is clean, no pinched lines. Im at a loss here.
Only thing that changed is the flywheel. Had a piece of steel get in there and chip a magnet, so i dug through our spare parts and found one that i believe is off of an XCR 800 engine. Triggers all line up, everything is the same except for one trigger on the original ultra flywheel. On the original there was one trigger that was about 3 times longer than the other two. Lighting coil seems to be out, but the exciter and the trigger check out ok on the stator. I dont know how having that one trigger not be longer like the stock flywheel would make any difference, but i figured id throw that out there for someone who may know.
Thanks for any input!
