Not sure if anyone has done this yet…
Mod is to remove the screws used to hold the cover plate in place that is located just behind the steering post (between steering post and gauges).
Used a 10 mm bolt cut to length to just protrude above the cover plate and drilled a 1/8" hole in the bolt (now a stud as I cut the head of the bolt).
Stud was thread locked with blue #2 thread locker to hold in place.
Key ring clips were used to hold the cover plate in place - plastic washers were placed under the clips (optional). Works slick and reduces time to remove the cover plate.
