MM 700 Oil pump
P
pshaver8
New member
What is the best way to prime or bleed an oil pump on a 97 MM 700. And should i premix the first tank of gas?
There should be a phillips head screw between the first and second carb that you loosen or take out to bleed the pump. From there I generally just start the sled and let it dile to it is warmed up with the oil cable pulled to full length. That generally is all that is needed.
