Minor gauge lifter mod
O
Oregonsledder
I made a couple of little add-on brackets to lower my gauge in the gauge lifter so it would be at or below the level of the short PRO windshield. I can remove it and attach the gauge back where it originally was if I decide to add the SLP air intake.
your sled is on without the key!!!!
looks good :)
Yes it is. There is a little known secret, that Polaris doesn't publish. You can pull the key out right after you put it in and turn it just a little, and it will be in the on position without the key.
Or you can just jam a knife in there and turn it to the on position. First upgrade was a different ignition setup.
