MF boots sizing
Superduty348
I have a question about the new MF stomper 2.0 boots. I currently have the original stomper boots in a 13. Now how do the 2.0s size up ? are they the size as the original sizing for they guys that have got the new 2.0s .
thx in advance
Get a 12. My 2.0 11's run the same size as my original stompers in size 12.
I ordered one size larger than actual size I wear. I have to use the insert for boot to fit properly but I don't mind.
So, your best bet is to order your the size you regularly wear and you should be fine unless one foot is larger than other than order one size up and use insert as appropriate.
So far we have most people order true to size, and they will wear a warm insulated sock and fit well. The 2.0's def run large.
How do they compare to Klim?
I have size 14 Klim Arctic GTX and they are a little small...not enough for me to care though I wear the thinnest sock. I think MF is the only other company that makes a 14 ( that i could find ) so just curious.
