I've been playing around with google maps and started a trail/points of interest map for Mt. Saint Helens.
Anybody that has a google account and clicks the link below can edit and/or add to the map.
Hopefully some of the locals and regulars will help out and get this new map setup.
Click this link: Helens Map
I encourage all to participate as it will be beneficial to all!
Placing a Marker:
Please zoom in on the map to accurately locate your marker point.
To add a pin:
simply click the pin (Add A Marker) located right below the search bar and just to the right of the little hand. Your cursor should turn to a "+" that you locate where you want the pin then simply click your mouse. Then you can label the pin.
To draw a line:
Click on the draw a line tab located right below the search box. Click on the map to start the line, click everywhere that you want to change direction, and double click to finish the line. Then you can click the paint can to change the color and thickness of your line.
If you click the drop tab by "Base Map" at the bottom of the info box, you can select Satellite (shows trees and open areas), Terrain(Topo View), Street Map, ect to change the map.
In the info box on the left side, hover over a line or pin to see where it's located on the map. Click and more info will pop up on the map.
Thanks for any that add to this map.
I hope everyone gets tons of snow and has a safe riding season!
Placing a Marker:
To add a pin:
To draw a line:
