M
moderatebill
So I am in the process of repairing my second diamond drive with the mechanical reverse and hope to pass along some of the things I have learned.
First, I spoke with black diamond they even admit there is a weak point in these drives. They are working on a solution, so there is hope.
The problem seems to be in the planet gear and the brass/copper shims on both sides of each gear. The side load must wear them out over time and then things start to come apart.
From now on I am going to change my oil two or three times a year. Not that I think changing the oil will help, but to identify a problem before it becomes major. I also plan to pull the drive every off season and do a full inspection.
I almost didn’t notice the brass this time when changing the oil because it was stuck in the gear case.
First pull the cover off the drive and separate the gears to get to the planet assembly. Use a gear puller to get the bearing off the shaft of the plant assembly. Carefully take the assembly apart keeping track of every part. In my case only the planet was damaged and was able to order just that part from Black Diamond. Cat only sells the whole assembly for $300.
