C
Do the MDS weights really make as big as a differance as they claim? or should i stick with stock polaris weights?
Anything that can load the heel more will be better than stock IMHO. I use Bellybusters; they're not adjustable but a lot cheaper.
Have FUN!
G MAN
I can't say on the poo, but maybe this will help.
They work in the cats, I am going to try and get a friend to buy some for his pro so I can test them and report what I find, I ran them in a mod m1000 and they didn't work until I installed motor mounts and had my secondary rebuilt, then after those problems where fixed I saw the gain, on my TM8 at 10000ft on 6lbs of boost I pulled out the twisted clutching and installed the MDS setup on the hill and gained 9mph track speed, thats huge. Also cooler clutch and belt temps and the rpm's didn't bounce all over like before, after 4 10-15sec pulls I put my hand on the clutch and left it there to tell if it was hot, more like warm.
If I had a pro I would at least try them. FYI, if there is anything wrong with your clutching they will make things worse, or if you are not seeing the gains you think you should and have followed MDS's setup instructions call them and let them know, they will do there best to help you get what you are looking for, or refund the purchase.
Hymm well that sounds good!, mabey ill give them a try...
Wouldnt happen to know how much they cost would ya?
"At MDS adjustability was also a factor taken into account these weights have the capability of running 0-10,000 ft. with no moving parts, just straight forward thinking." Also would like to know if this is true? i ride around 1800ft and i go on mountain trips highesxt being probs 10,000ft so could i use the same weight?
Thanks
What about the Slp Mtx weights, are they not the same thing at 1/2 the cost.
