I'm looking for input of people that have used the MDS C1 weights. How did they work? Are they worth it? Any input would be helpful.
I'm running them in a 2010 M8 162. Stock except for a Skinz can. So far I'm very happy with them. We haven't had any deep, challenging conditions recently, but I'll tell you my experience so far. Most of my testing with these has been in snow where you would sink to knee depth, but could make a snowball. Read: Washington March-April type powder.
I was originally running 70g cat weights with a cat yellow/white primary spring. Stock secondary except for a shift assist bearing. Engagement was a hair under 4000 and it ran decent except for belt slippage at low rpm (crawling in the trees) and some heat on long, wide open pulls. Ran 8100-8300 rpm, depending on snow. I could get track speed down to 40 when really, really pushed (steep, deep, slow, etc.).
I started with ~77 or 78 grams in the MDS weights, per Steve's recommendation. Same yellow/white primary spring. No changes to the secondary. Engagement was up to 4300+ rpm. Stronger pull from 20-60 mph, and still some heat on wide open pulls. RPM was spot on between 8100-8200.
Switched to the D&D white spring and added 1 gram to the weight tip. Now engagement is nice and smooth, a bit under 4000 rpm. Even stronger pull from 20-60 mph. Great backshift. In deep heavy snow, I could let off the throttle mid-climb while barely moving, punch it and hit 8150 every time. Zero rpm loss when climbing. RPM was typically from 8150-8300, depending on snow conditions. Less belt slippage crawling in the trees. Less heat on a long, wide open pull.
I have yet to get some good deep pow for testing. Climbing the steepest hills I could find in heavy snow, leaving an 18" trench, I saw track speed from 43-48 mph.
On the hardpack in a rolling start drag race with a well setup 2009 M8 162 w/ SLP pipe, we were dead even (in case anyone really cares how your mtn sled does in a drag race....).
