Not sure if this applies here but if a guy want to run the upgrade and has the external pump does one just have to adjust the wasteagate? Set it so the low setting is 15 and the tpc thing will adjust to 17 lbs? Is there something else that has to be done? Fuel regulator? mapping?
call walt healy motors in calgary, i just put the external fuel pump on mine to feed it more fuel. the regulator is self adjusting and you set your starting pressure. i put a gauge in line and left it so i can check in about 1 minute the pressure. i should get pic and post if you decide to go that way.
How do you adjust the starting pressure? Again the early kits came with an external fuel pump. What is needed to be done to run stage 2 -17lbs?
I know I have the external pump but not to sure about the regulator ( I will check later). Lets say that I have both how do I increase the boost and still have the tpc thing self adjusting?
My kit is a early kit and it has the regulator????? If there is no regulator what is stoping the pump from continuously running until it pressures up high enough to stall it out???? They are not a on/off pump. If it has an external pump it has to have some sort of regulator.
