Mcx nytro issue. Doesn't build boost
B
bigbird
Had to tear my sled apart to replace starter. I have missed something putting it back together. Sled idles great, runs fine until it calls for boost. Will slowly ramp up boost to about 5 lbs. and that's it. I've checked every connection 4 times and am very confused. Any help appreciated. It's an mcx 270 kit
Put a small amount of air into the box and the inj should fire and at idle it will flood her out or stumble heavy. Then u know there working for sure
Probably a boost leak. Get a piece of abs pipe diameter of the intake side of turbo. Glue plastic abs cap to abs pipe. drill a hole in cap just smaller than air chuck. Heat chuck and thread into cap. Put 15# of air into intake and listen for air leak.
