W
Washy
IT seems to happen when running the sled for about 5-10 minutes. After running it hard back and forth in the feild it will pop the fuse either one or the other. I ran the sled out of gas once last year and that is when it started blowing the ignition fuse. Now it will either blow the ignition fuse or the main fuse. What do you think. I replaced the fuel filter and still pops fuse. I am thinking it is the MCXpress external fuel pump but looking for suggestion. All connection dielectric greased and no moisture anywhere. Not enough snow for moisture.
After replaceing the blow fuses it runs perfect, until I run it hard back and forth in the feild.
I looked for any wires chaffing on underneath the handle bars, seems good. and cant see anything chaffing on the clutch side where the wires run along the inside of the bulkhead.
