May want to check your Turbo pump. Reach down and insure that the oil tank isn't touching and try to turn it. If you can turn it you may have the shear pin broken. If you can't turn it all is well.
T Bird have you priced out that little pump? When I got my kit my pump was machined a tad wrong....the gear was pushing on the end plate when it was tightened up and it ruined it....but MCX covered it but I saw how much the new one was How much are they over there?
pump was like 900 CAD
Yikes!! Should become a machinist and make some up!! I had to send mine back because the bolt for the banjo fitting was machined crooked it leaked like a sieve!
The main pump body screws into the cover if you can turn it, it just means it hasn't been tightened enough. When installing it you have to use the screws and a screwdriver to torque it up enough. Just did it on a buddy's engine like two hours ago. The only way to check the drive pin is to remove the main body completely. Which I think you would only have to do about every 2000-4000 KM's or every 2nd or 3rd season.
