Ok to start I am kinda new at this and I just want to make sure that I am not damaging my engine? I need to mention that I am a flatlander and run my Nytro at 1000ft to 1500ft in elevation.
My first few hundred miles I could only get 165KPA(approx 9psi) on the MCX display and running 12.5 A/F at WOT. So, I decided to shorten the wastegate rod two turns and I filled the tank and added 1 gallon of 100LL avgas just to be safe?
Now. I am running 175KPA with a A/F of approx 12.8 ish? When I smack the throttle it immediatly reads 13.5/13.9 and slowly creeps to 12.9 and I need to shut it down since I am out of room in th field I am testing in. Maybe If I had more room it would come down....who knows? Does adding boost lean it out?
I would rather hit the gas and see a 10 or 11 AFR and creep on to 12 or 12.2 ish wouldn't that make more sense?
Please give me some advice so I can get this thing on the right track?
One more thing is that I cannot get my MCX display to communicate wih my laptop? My buddy's laptop works so I can add fuel if need be?
