After putting on 2000 kms on the 180 kit this past season, here's a quick summary of problems.......ZIP! Other than me hitting a tree near the end of the season and taking out the turbo pump/magneto cover, the sled ran flawlessly. Need a brace to protect this area.
I just took it all apart this past week for an inspection, the only thing I found wrong was that the air cooler tube that passes from the tunnel area up and through to the plenum intake hose, has a severe wear spot on it. It would appear it was rubbing on the tunnel where the hole is cut for it to pass through, almost cutting right through the aluminum pipe. This area has been "rubberized" to prevent further damage. Everything is still tight, nothing whatsoever loosened up anywhere, indicating that the fit and finish of the kit was second to none.
One thing to make sure of is when you route the braided lines, to ensure you put some rubber over them where they might rub against something. I noticed a bit of abrasion on the head cover from where the turbo pump line was routed.
There has been many posts on the power that these kits put out and that riders should opt for more HP. From the 3 of us that have these kits now on our sleds and for 90% of the guys out there, you don't need more! Sherm
