Maybee someone knows
Why Do You Want To Remove It? I Would Leave It If It Is Still Working
But If You Are to Remove It There is Just One Line That You Plug The One That Goes To One Carb in A Different Spot Than The Other Carb This Is The Vacumm Line So Plug It. Then Just Take The Carb Vent Lines & Hang Them Down Past Carbs, then You Will Have The Joy Of jetting Carbs Down. If You Can Find a Older Model Without Alt Compensator & Use That For Jetting Guide
Per Alt & Elevation & Temp Hope That Helps.
If it is working I would leave it alone.
I personally haven't tried to remove it. But I know several others that have and they never got them to run right. Fighting the jetting all the time.
Thunder
