J
jaminfire
New member
So I get the same question all the time when selling sled decks... What is the maximum width a sled deck can be to be legal. I am no Attorney but I can use a computer.. In the general snowmobiling section of snowest this topic came up. A Cop in the McCall area has been giving tickets for sled decks because they hang over the sides of trucks. If this happens to you stand up and complain to the Idaho State Police. If we file a false police report we would get in trouble. It should be the same for a police officer wrighting a false citation. So here is what I found...... In general 8' 6" Max
Oregon Law
SIZE
818.080 Maximum size limits. This section
establishes maximum size limits for purposes
of ORS 818.090. Except where an
exemption under ORS 818.100 specifically
provides otherwise, any vehicle or load
thereon that exceeds a maximum allowable
size as determined by any of the following
tables exceeds the maximum size limits for
purposes of ORS 818.090:
(1) A vehicle or combination of vehicles,
as appropriate, exceeds the maximum allowable
size if a dimension of the vehicle, combination
of vehicles or load thereon is
beyond an applicable maximum size allowable
on the following table:
__________________________________________
TABLE I
Dimension Limit applicable to: Maximum
limited: allowable
size, in
feet, for
dimension
limited:
(1) Total
outside
width.............Any vehicle........................ 8½
(2) Height,
including
load................Any vehicle........................ 14
(3) Length...........Any vehicle
operating singly................ 40
Vehicle in
combination
of vehicles.......................... 40
Combination of
vehicles,
including load ................... 60
Combination of
vehicles that includes
a stinger-steered
pole trailer......................... 65
(4) Length of
load on
vehicle...........Any vehicle
operating
singly or as a
unit in
a combination
The maximum limit on height under the table
in this subsection does not relieve the
owner or driver of any vehicle or combination
of vehicles from the exercise of due care
in determining that sufficient vertical clearance
is provided upon the highways and
streets where the vehicle or combination of
vehicles is being operated.
(2) A vehicle or combination of vehicles,
size if a portion of the vehicle, combination
of vehicles or load thereon is subject
to a limitation under the following table and
that portion extends farther than the maximum
limit of allowable extension beyond a
designated point as determined by the following
table:
TABLE II
Designated point: Limit applicable to: Maximum
limit of
allowable
extension
beyond
designated
point:
(1) Line of left
fenders of
vehicle..............Load on any
passenger
vehicle ........................ No
allowable
extension
Title 59 Page 349 (2005 Edition)
818.090 OREGON VEHICLE CODE
beyond
designated
point.
(2) Line of right
fenders of
passenger
vehicle ........................ 6 inches
Idaho Law
TITLE 49
MOTOR VEHICLES
CHAPTER 10
WEIGHT, SPEED AND TIRE REGULATIONS
49-1010. SIZE OF VEHICLES AND LOADS. No vehicle shall exceed the
dimensions specified below, except that certain devices determined by the
board as necessary for the safe and efficient operation of motor vehicles,
including energy conservation devices, shall be excluded from the calculation
of width or length.
(1) The width of a vehicle, including any load thereon, except as noted
below, shall not exceed .......................................... 8 1/2 feet.
(a) The limitations as to size of vehicles stated in this section shall
not apply to farm tractors or to implements of husbandry, including any
load thereon, or any trailer not wider than the implement of husbandry
used in the transportation of implements of husbandry for agricultural
operations, and including all equipment used in land leveling operations,
when being incidentally operated upon the highway from one (1) farm
operation to another during daylight hours.
(b) Notwithstanding the exemption from width limitation for farm tractors
included in paragraph (a) of this subsection, the total outside width of
any farm tractor being transported on the interstate system in this state,
except as permitted by section 49-1004, Idaho Code, shall not exceed
.................................................. ................ 9 feet.
Washington State Law
RCW 46.44.010
Outside width limit.
The total outside width of any vehicle or load thereon must not exceed eight and one-half feet; except that an externally mounted rear vision mirror may extend beyond the width limits of the vehicle body to a point that allows the driver a view to the rear of the vehicle along both sides in conformance with Federal National Safety Standard 111 (49 C.F.R. 571.111), and RCW 46.37.400. Excluded from this calculation of width are certain devices that provide added safety, energy conservation, or are otherwise necessary, and are not designed or used to carry cargo. The width-exclusive devices must be identified in rules adopted by the department of transportation under RCW 46.44.101. A width-exclusive device must not extend more than three inches beyond the width limit of the vehicle body.
Navada Law
MAXIMUM WIDTH NRS 484.759
• 102 Inches excluding: Mirrors, lights, other safety devices, and any hardware required for an awning, which does not extend beyond any mirror that is attached to a recreational vehicle.
• If equipped with pneumatic tires, maximum width from the outside of the wheel and tire to the outside of the opposite outer wheel and tire must
California Law
GENERAL RULE
35100. (a) The total outside width of any vehicle or its load shall not exceed 102 inches.
MEASUREMENT
35100.1. (a) The metric equivalent of 102 inches is 2.6 meters.
(b) The width measurement of any vehicle with side walls shall be made from the outside wall of the two opposite sides of the vehicle.
CITIES & COUNTIES
35100. (c) A city or county may prohibit a width in excess of 96 inches upon highways under its jurisdiction.
35105. Any city organized under a freeholders' charter may permit a width in excess of these limits when used within the city.
VEHICLE & LOAD EXEMPTIONS
35101. When any vehicle is equipped with pneumatic tires, the maximum width from the outside of one wheel and tire to the opposite shall not exceed 108 inches.
35100.5. The outside width of a cotton module mover and the load thereon shall not exceed 130 inches in width. For details, see the web page: Cotton Module Movers.
35102. When any vehicle carries a load of loosely piled agricultural products such as hay, straw, or leguminous plants in bulk but not crated, baled, boxed, or sacked, the load shall not exceed 120 inches in width.
35104. The following vehicles shall not exceed a width of 120 inches: (a) Special mobile equipment. (b) Special construction or highway maintenance equipment. (c) Motor vehicles for hauling feed for livestock that are exempted from registration, except when operated on a highway during darkness.
35111. No passenger vehicle shall be operated on any highway with any load extending beyond the line of the fenders on its left side or more than six inches beyond the line of the fenders on its right side.
Oregon Law
SIZE
TABLE I
limited: allowable
size, in
feet, for
dimension
limited:
(1) Total
outside
(2) Height,
including
Vehicle in
combination
Combination of
vehicles,
Combination of
a stinger-steered
(4) Length of
load on
operating
singly or as a
unit in
a combination
table:
TABLE II
limit of
allowable
extension
beyond
designated
point:
(1) Line of left
fenders of
passenger
allowable
extension
beyond
designated
point.
(2) Line of right
fenders of
passenger
Idaho Law
TITLE 49
MOTOR VEHICLES
CHAPTER 10
of width or length.
RCW 46.44.010
Navada Law
California Law
GENERAL RULE
MEASUREMENT
CITIES & COUNTIES
