2" on tall bars works. I'm 6'5 and am running a 2" block with the Fly/NXTLVL bars (which are a little shorter than the tall protaper). I wouldn't go any taller regardless of cable. It's a good setup for my height relative to the height most shorter riders are using. You get plenty of control and it is comfortable when you get used to keeping your knees bent - which is important anyways. In other words, it forces you to be a better technical rider and avoid the pitfalls of having bars that are too high/tall. That being said, you also might be able to at another 1/2 or so if you run a finger throttle.
Also, you might really like getting different bars and rips. Stock bars and grips have a pretty small diameter for people with bigger hands. Putting the ODI ruffian grips on fly bars and cheetah bars have given my hands a lot of relief. I tried running RSI bar hooks on the protapers for a while, but it's way too wide - and if you cut the bars down in width they no longer accept the hooks because of the internal "taper"
