im not trying to steal your thread but i was wondering the same thing on a m7 riding about 4500 to 6500. thank you
Im far from some guru, but have experienced plenty of pleasure and equal heartache after 4 years of messing with the M6-M7. Ive found different results depending on multiple factors. These being primarily fuel controllers and regulators. I experimented heavily last season. Enough that I didnt ride much between screwing around and burning down.
My findings with a 2860:
I will tell you right now a stock m7 fuel pump will not fuel 4 injectors.
At 8lbs, a stock M7 pump will not provide the additional 16lbs pressure (2:1 regulator). The pump simply can not keep up with the demand.
At 8lbs and 2 injectors with a 1:1, you can make it work with a BD box, BUT, on longer pulls you will see fuel pressure diminish. 4-5lbs was about my max finding.
(PM mtnmikeonboost if you have questions about your aerocharger. I think he was able to run his stock fuel pump with 2 injectors around 8lbs if I can remember right).
Other note: The BD fuel box seems to have more ability to max the injectors out than my PL box or AI box.
I have tried several different pumps and setups over the couple seasons.
Theres probably only 2 approaches I havent tried, one being:
Using the stock pump with an intank 1:1, BUT ALSO running a secondary fuel line directly from the tank through an inline pump to the aux. (secondary) fuel rail with its own dedicated regulator. Im running 4 injector throttle bodies so this test/option was off the table for me unless I go backwards a bit. The problem with these experiments is not being able to control the fuel amount balance between the main and aux injectors.
Ive moved away once again from the stock in tank pump.
That is definitely the question. No one seems to agree.Wow big difference from what a BD rep tried to tell me??? He said up 300 HP with the BD PG 1000 kit on stock injectors! Is this not true?
