Max Boost on Sunoco 110
D
DTrip
Max SAFE Boost on straight Sunoco 110
06 M7 Boondocker Kit
4000'-6500' - Typicall riding elevation
I know guys are running 8# with a couple gallons mixed in on the M-8 Pump Gas kits. They also have the advantage of a knock sensor, so I guess they can push it a little bit.
Whats your guys experiances???
I'd say about 12#, maybe 13 or 14 but I think you are pushing it. That's what it is for 1000 anyways. May be different on the M7 turbo.
I had an 05 M7. I ran Avgas, which is supposed to be 100 MON. I ran 10 lbs Lowest I rode was 7000 feet, usually above 8000. I put on 700 miles. I checked the pistons after every ride. No signs of detonation.
Seems like racegas would be good for more than 10 lbs.
10-13 at your elavation but use an AFR guage and check pistons because as you know every two stroke is a little different
